View Full Version : Glass Shelves
az1324
03-02-2006, 02:10 PM
I need to put glass shelves in a frameless 42" upper dish cabinet but am nervous about their weight bearing capacity. What thickness of glass would you recommend and is support at only the two ends sufficient?
03-02-2006, 08:11 PM
use tempered glass and you will not have to have a real thick glass shelf. Even with that, the more support the better.
finnegan
03-02-2006, 08:48 PM
I replaced the shelves in a few cabinets with glass in the last place I lived. I think I used 1/4" glass, but I recall that the place I got it from was helpful. I would check with your local glass and mirror supplier, they will probably point you in the right direction.
toolaholic
03-05-2006, 08:47 AM
I do a lot of glazing .temp is also 9 times stronger than annealed glass.
when i was doing a lot of store fixture work in the carps. union we would sometimes cut down glass shelves.they were 3/8 annealed. not tempered
