View Full Version : Kenmore Water Heater Install
art_d
12-07-2004, 11:36 AM
On my new kenmore power miser 12 there is a blue plastic tube all the way up into the cold water inlet, threaded portion. I'm assuming this is the dip tube. Is this suppose to be up that far? And, how do I thread my heat traps into the cold water inlet with that in the way?
Thanks
jadnashua
12-07-2004, 05:59 PM
Is it a hollow plug put there to keep crud out until it was installed?
The Pipe Rat
12-07-2004, 09:38 PM
The dip tube should slide into the threads and still allow you enough room to install your "Heat trap" nipples.
art_d
12-08-2004, 02:18 PM
Can someone recommend someone that can install a gas direct vent water heater on the Eastside, Seattle area? I'm sick of working on this
