wallyjopper
- Messages
- 1
- Reaction score
- 0
- Points
- 0
I am building a solar water heater foor an above ground pool. This is being done on a 8ft by 16ft backboard angled at 45 degrees.16ft being the width.So the heigth at 45 degrees will be 4ft. It will be constructed from 1.5 inch black abs pipe. it will have a header pipe up the left side for intake and one on the right for output.it will have 17 1.5 inch 15 ft long pipes between the headers with reflectors behind each pipe. The total of the pipes will hold about 25 gallons of water.I have a 1 hp pump that pits out 40 gallons a minute. I need to know if the pump will be able to fill all the pipes with the 4 ft rise and still be good on preasure and volume for return to the pool . the collecter will be between the filter and pool. Any help would be apprec.
