View Full Version : Acrylic tubs and Firewall in a condo
Kyle Ashley
02-17-2006, 12:17 AM
Hello,
I am remodeling my bathroom and am replacing my old steel tub with a new acrylic jetted tub, 32x60. I'm in a condo, and the old tub was set against a firewall that is common between 2 units in the building.
The old installation on the steel tub was 1 sheet of 5/8 Firecode Drywall from concrete ceiling to concrete slab floor, and a 2nd sheet of 5/8 Firecode drywall that ran from the concrete ceiling and then overlapped the tub's tile flange and ended. The firewall is only along the long side of the tub. The back wall and fixture wall was standard 1/2 inch drywall.
I have heard that the fire code may be different for acrylic tubs than steel tubs. Does that mean I'd need to have 2 full length 5/8 Firecode layers of drywall from ceiling to floor before the tub wall, or can I install the acrylic tub in the same manner as the old steel one?
I'm in Florida if anyone there would know the code better.
Thank you!
02-17-2006, 07:11 AM
Your city's building department is the only one who can tell you what their requirement would be.
Kyle Ashley
02-17-2006, 07:46 AM
Thanks for the post! Unfortunately, our building dept has no consistent answer. Different inspectors say different things and I can't really get a straight answer from anyone at City Hall. They basically require me to pull a permit and pass inspection on the wall before I can install the tub.
jadnashua
02-17-2006, 10:27 AM
In a situation like that, maybe it is time to ask for the department manager to make a call. Trying to rely on different inspector's varying opinions is not productive for anyone.
Spaceman Spiff
02-17-2006, 07:49 PM
A 1HR firewall is made up of 1 layer of FireX wallboard on each side of a 2x4 or steel stud. A 2HR is 2 layers on each side. Since there wasn't the second sheet to the floor it sounds like a 1HR wall. Underwriter's Labs doesn't test tubs as part of a listed firewall assembly.
I would keep the 1 layer all the way across and if you're nervous, carry the second layer all the way across, with a third over the lip of the tub. It won't hurt to have two layers.
Kyle Ashley
02-19-2006, 11:31 AM
Thanks for the tips! I am going to run 2 full layers of 5/8 all the way down as I have the room for it, and then add a top layer of 1/4 hardibacker to overlap the tile flange on the tub. I'm not tiling, but using a solid surface tub wall kit that will glue to the hardibacker. The wall material is non-porous so I should be OK with that.
The original installation had regular 5/8 gypsum board and the tiles were just glued on the 2nd layer of gypsum board with a small amount of glue. No thinset was even used. It held up OK for 32 years since it's a guest bath, and only used a couple of times a month for the tub, not shower.
Gary Swart
02-19-2006, 01:11 PM
I think you're probably headed in the right direction. If there is confusion on the requirements, go the extra mile and CYA. It won't hurt to have the added thickness even if not required, and the addition expenses will be minor.
Kyle Ashley
02-20-2006, 11:29 PM
Thanks Gary....once we pass inspection, I'll post back.
toolaholic
02-26-2006, 08:14 AM
because of the bld. dept. history. ask them to write it down and sign it.
with a smile on your face :D not unreasonable :)
toolaholic
02-26-2006, 08:21 AM
if you thinset tile over sheetrock it's a temp tile job! unless you have an
EXPERIANCED tile person do a mud job with wire. $$$$$$
ask if you can use 1/2" dura rock , concrete board, than you will have a long lasting affordable job :) and it's higher fire rated!
Kyle Ashley
02-27-2006, 10:42 PM
I did change my mind and decided to use 1/2" cement board as my second layer. Should have it done and ready for inspection by Friday. I really went overboard making it solid and placed metal studs every 9 inches. The old stud distance varied between 17-19".
toolaholic
02-28-2006, 07:28 PM
and good decesion ;)
Kyle Ashley
03-07-2006, 01:09 AM
Inspection passed! No problems. Thanks for the tips and pointers! Now things can move along rather swiftly and the big stressor is off of me.
Inspector never said a word or asked a question....He just agreed with me that finding someone willing to work in a condo is impossible no matter the $$. He seemed to understand the frustration of not being able to hire the job out. I will rest easy tonight :)
