Prashster
- Messages
- 936
- Reaction score
- 5
- Points
- 0
Are rubber dwv fittings up to code?
Is it 'to code' to use rubber, flexible sanitary tees on exposed drain lines to join a horizontal sink drain line to a vertical drain stack?
I'm trying to figure out how to configure my sewage ejector pit vent. I've attached a pic to show how it's config'd for discharge (please comment if you see problems on the discharge; I haven't had the inspector over yet, but am planning to.)
The vent hole will receive three pipes: a utility sink drain (you can see this along the left side wall), a bathroom sink drain, and the vent pipe. I can merge the 3 pipes into one with 2 sanitary tees, but I'd like to be able to remove the contraption easily for pump servicing. The rubber tees would save me having to use a separate rubber coupler with a pvc tee.
Also, is it ok to use sanitary tees in this way? Or do I have to use wyes? It's only sink waste, afterall.
Thanks in advance. This forum rocks!!! (Jeez, what did people do b4 the Internet?)
