well pump noise; long cycle
Leaper
Sarasota, FL
The past couple of days my well pump has been excessilvely noisy and seems to run at every demand for water. For example, when the dishwasher or washing machine is on, the pump runs the whole time instead of building pressure and cycling off. It does not click off and on; it runs constantly with each demand for water. My pressure gauge is not showing any drop in pressure. The water pressure in the house is not noticeably different.
I have a bladder tank and am not sure how to tell if the problem is with the pump, tank, pressure gauge, or the well.
Any advice would be greatly appreciated. I am afraid to use the water for fear of serious damage.
It is a good thing that your pump does not cycle. Cycling is hard on the motor. If you have a jet pump, you may need to have new bearings put in the motor. Most motors here in Florida (they are outside in the weather) last 7 years before needing bearings.
If the pressure is good, you shouldn't hurt anything by the motor running as long as water is being used.
bob...
