Shower Valve Question
dkn63
I am in the middle of a bath remodel and at the point of plumbing in the shower valve assembly
my question is : what is the best way to mount the valve and the 90* nipples so they will be at the correct depth to the finished wall
I hope that makes sense
thanks, Doug
your directions should have a min and max to finished wall from center of inlet. do the math and mount a 2 x 4 between the studs at the right depth. plus don't sweat directly to the valve unless you take it apart.
It is essential that you have the control you want to put into the wall or at the very minimum the detailed spec sheet so you can understand the setback required. Pretty much all decent valves will tell you how deep from the FINISHED wall surface the valve needs to be to enable the trim to fit properly. It is far easier to do if you have the valve. Use brass/bronze dog-eared els so you can screw them to a piece of blocking that will hold the things at the right depth.
