jimtrusk
02-07-2006, 10:02 PM
Hello everyone, This is my first post here. We live in Frederick, MD. I hope someone can help with some info. I haven't found anything in a quick search.
After a remodel the drain centerline to wall distance is 11 3/8 " in our hall bath due to new tile. It appears to me that our new Carlyle won't quite fit. I placed the 12" uni-fit over the drain flange, lining up the bolt holes and the back of the uni-fit is no more than 3/8" from the tile wall. The spec sheet doesn't appear to give the exact measurement I need to determine if I need the 10" uni-fit or not. I would rather not use it since it would move the toilet closer to the tub. Does anyone have any experience with this toilet? If I do need the 10" uni-fit I would like to order now so the plumber can do everything in one visit. Are there any other solutions to move the drain flange connection by 1/2" away from the wall. Right now there is tile around the drain flange itself so it can't be moved without rework and expense.
Also, the drain flange is now about 1/4" under the floor tile level. Does this require an extender? The extender box says it is for flanges lower than this.
Any suggestions are appreciated.
