JerryMR
I had three Aquias installed about 4 or 5 months ago. Overall I'm very happy with them. However, they all suffer from the same issue, namely that more often than not, pushing the number 2 flush button only flushes the same amount as the other button. Occasionally it will flush the whole tank, but usually not. This happens whether I push with the button on the lid, or if I take the lid off and push the button directly inside the tank. The tank fills to the correct height, right at the fill line. And the low flow flush lowers the water level by 2 or 3 inches. All three toilets were installed by the same person.
I've been getting along by juts holding the button in until everything flushes, but I've reached the point where I'd like to improve the situation. Is there something simple to adjust which will fix this? Looking at the manual, I only see an adjustment for the low flow flush amount, not the high flush.
Thanks,
Jerry
Thanks,
Jerry
