View Full Version : New drain for washing machine in condo
smiralira
02-01-2006, 04:42 AM
Hi everyone,
Considering purchasing new washer and dryer for condo, only problem would be the drainage. Their is no existing plumbing for washing machine, but the closet it would go in would be next to kitchen with sink and dishwasher. Would it be possible to drain to sink 1 1/2"? Or should I forget about it? Condo is on 2nd floor. Any comments would be greatly appreciated.
smiralira
Cass
02-01-2006, 04:52 AM
I suggest you get a competent plumber to come and look at it and let them tell you if it is possible to add a washing machine drain line.
What you are suggesting may or may not work, washer lines should be 2".
smiralira
02-01-2006, 05:05 AM
I'm sugesting to run to drain hose to the p trap under the sink and have to sink act like a basin, would that even work?
Cass
02-01-2006, 05:12 AM
You can try just running the drain hose right into the sink and see if it will drain fast enough to keep up with the washer.
Gary Swart
02-01-2006, 08:51 AM
Washers today dump a huge amount of water in a very short time. I don't think running the drain to the P trap would be proper although it might work by forcing the water that the drain can't handle up into the sink. A washer's drain hose is supposed to hook over a standpipe and is not plumbed solidly into the drain. However, the drain must be 2" to deal with the large volume. Since the 1-1/2" sink drain is too small to handle the load, using the sink as Cass suggests is probably your best bet. The sink will act as a temporary holding tank until the small drain can handle it. Obviously, the real right thing to do would be to put in a 2" drainline to the main drain.
02-01-2006, 09:24 AM
Many condos have plumbing "back to back".
A problem you have, may be shared by your neighbor.
The washer should drain into a 2" line for starters.
If you open the wall, you may find a 2" line to work with.
The vent for the washer can be revented above the height of either the washer drain or the sink, which ever is highest.
smiralira
02-01-2006, 05:24 PM
Thanks everyone!, i'll let you know what I plan to do and if it works.
jimbo
02-01-2006, 09:28 PM
I am on the board of my condo. We have WM in the units, but if we didn't, we would take a VERY dim view of anyone installing one. Here in California , at least, it seems the association is responsible for most damage done to the common are ( walls, ceilings, etc. except for the paint). Most homeowners do NOT have liability insurance, if you can believe that. Suing them is usually fruitless even if damage caused was their fault.
We would at a minimum require a very robust drain pan with a drain line plumbed to it. We would not allow you to tie into a 1 1/2" line because that is a recipe for an overflow. The line in the wall is probably 2", so this might fly. If you needed access to another unit for plumbing or electrical work in the walls or ceilings, we could not force the other owner to comply.
We have pancake FAU with direct vents. One owner wanted to replace it with a conventional unit which would have required penetrating the (flat) roof for a flue. The answer was NO WAY JOSE! We guard our roof integrity like it was a firstborn child!
smiralira
02-03-2006, 05:04 AM
This is a portable WM and I have decided to just roll it out and hook it to the sink and also drain it there.
Thanks for all your comments
toolaholic
02-03-2006, 08:05 AM
avoid all the assoc. fines ect. this isn't listed in the code books or UCMJ
run the hose out the closest window. works wonders for the grass also.
that's what we do back home :)
Gary Swart
02-03-2006, 09:01 AM
I'm sure the condo association would just love to see a hose dumping wash water out a window! ;)
smiralira
02-18-2006, 12:39 AM
Hi everyone, just an update that I ran 5/8" drain hose that came with the washer and ran it though the wall in to the kitchen faucet drain that is 1 1/2" and hooked it up with a dishwasher pvc drain pipe adapter, works along with the dishwasher drain and both work like a charm.
