View Full Version : Cast Iron Flange - Gone!
dlsteinberg
01-30-2006, 09:58 AM
Last night I pull the 40 year-old toilet out of the powder room only to discover that the flange is gone. The pipe is cast-iron coming through a slab. It looks as if someone busted the flange off completely and tried to compensate with one of those horn-equipped wax rings and anchors straight into the slab. Now the orginial tile was thin (like vinyl) but I am replacing it with ceramic tile. Do I have any options that don't involve busting concrete?
David
(Tired of busting concrete)
David
Yes, they make a PVC flange that will go into the CI pipe and then you will drill into the concrete to anchor it to the floor. Check the big box store L***s.
It has a rubber seal on the outside of the flange pipe that seals to the inside of the CI pipe.
plumber1
01-30-2006, 10:26 AM
I still prefer to lead on a cast iron flange.
No pvc for me, but if you believe that will be easier go right ahead.
