The attached drawing shows my best effort to get on paper what I need help with. The venting is my biggest concern because there is a recently finished attic that I would rather not tear into to get a vent to the outside. Is it possible to use air admittance valves in the designated locations to avoid going through the attic?
On the 2nd floor, he laundry box and tub will be less than 2 feet from the 2" vertical drain line. Will they need a separate vent line? I added a dotted line as a general location if they do. The floor drain does not currently exist but it will be close to the vertical as well. A vent there as well? I'm thinking the AAV at the top of the vertical run will be brought back into the room for access.
On the 1st floor, there is a half bath that will tie into a 3" main that leads across the basement to a 4" stack with outside vent. The run is about 16 feet. I figured the AAV for the lav can sit inside the vanity and was thinking about bringing the AAV for the stool up through the floor and trying to hide it behind the stool. I know it sounds funky but wonder if it would work? Or if there are any other obvious problems.
