scubarob56
in my earlier post i noticed a typo......do i run the main water supply to pex manifold the to water heater using open ended manifold so that it will supply both the water heater and the rest of the house? it should read: do i run the main water supply to pex manifold then to water heater using open ended manifold so that it will supply both the water heater and the rest of the house? in other words, on an open ended manifold, connect pex from main water supply to top of manifold opening, then run pex to from bottom manifold opening to water heater, then use the 1/2 inch barbs to supply the rest of the house cold water????
