View Full Version : ultramax dirty bowl
cattledog
01-29-2006, 01:20 PM
Hello--
I recently purchased and installed a round bowl Toto Ultramax. As I expected from reading this forum, the flushing performance is very good. My issue is with residual bits of fecal matter sticking to the side of the bowl. It would appear that because of the "suction" flush with the majority of tank flow injected into the trap rather than into the bowl any bits of matter hittting or blown onto the side of the bowl rather than dropping into the water are not well cleared. There is some flow down the side of bowl during flush, and the water spot is the correct size. The toilet appears to be working as designed.
Previous toilets I have owned, both high and low flow, seemed to direct the primary flush flow into the bowl and had better side clearing action. Perhaps the bowl emptying flush performance was not as good, but the side cleaning performance was better.
Does anyone have any advice on how to improve the perfomance of the ultramax? Will sanagloss improve the side cleaning performance during the flush? Is there another model or brand of toilet with better clearing action on the sidewalls above the water spot but still has good bowl emptying? What about models with a higher/larger water spot?
Thanks for any advice.
SteveW
01-29-2006, 01:59 PM
Have you tried Chlorox toilet bowl cleaner with Teflon? Terry has a thread on this below. I haven't tried it myself, but certainly would run out and buy some if I were in your shoes.
Mike50
01-29-2006, 02:13 PM
You beat me to it Steve. I've been using Clorox with Teflon as recommended by Terry for a week now. It just might turn your sticky situation into the desired slippery situation. My money is betting it will
largely solve the problem.
Let us know if you try it.
SteveW
01-29-2006, 05:47 PM
It just might turn your sticky situation into the desired slippery situation. .
Baaaaad pun! (Wish I had said it...)
