Bathroom slow drain. Very odd problem !!
ianmulluk
I have a very slow draining sink in the bathroom.
I have removed the p trap and cleaned it out.
I have cleaned the other pipes and can pour water down them successfully.
I can pour water throught the p trap when it is not connected.
HOWEVER - when I reconnect it all , after only 1 cupfull of water down the sink it starts backing up .
How can this be ??
The p trap works fine when i disconnect it and run water through it and we have NO blockage
Really Odd - HELP !!
Thanks
Ian
Slow drain
I've seen older homes that did not have a vent for the bathroom basin. That's what it sounds like to me. Check to see if there is a vent or if the vent is blocked. If there is no vent at all, you might look at a Studor vent for the basin.
Remove the pop-up and inspect inside the drain.. There may be an obstruction in the overflow holes in the tailpiece.
If as little as one cup of water backs up I agree that the problem is right there in the pop up drain assembly. An amazing amount of "gook" ( soap mixed with decaying hair) can build up there.
