Hello All,
Last winter a pipe in an outer wall first floor bathroom busted due to the freezing cold and there being no central heat on in the house for a few days.
I finally found the break in the line after ripping up a section of that bathroom floor and crawling under the bathroom (I have an older home and I'm pretty sure that bathroom was a later addition).
Now that I have the break in front of me, I'm not totally sure how to proceed.
I don't know what type of repair would be best. I'm not afraid to solder and have capped and sealed a pipe before with a torch and solder.
However, it's such a clean break, I don't know if I should just try to butt the pipe back up to the T-joint and solder or, try to use a sleeve, or what.
The pipe is not in a place that's very accessible so, I want to make sure I do it right the first time.
Any suggestions?
Thanks, in advance!
Here's the pics of the pipe-
Any suggestions?
Thanks, in advance!
