Matthew Epperson
Hey, I'm looking for a place to ask some advice if you guys don't mind.
We've had a lot of rain here and this morning my sump pump was going off every 20 minutes or so. Getting under the house I at first was convinced the main water line had a crack, but when I turned the house water supply off and checked the meter, it wasn't moving. So, this has to be rain run off. I know we have a negative grade along that side of the house. So, I guess my question is, will a french drain fix this problem, or is it a bigger problem? The fact that the water has eroded the earth under my foundation around the water line worries me. :/ The main line is pvc not galvanized for some reason.
Also, our sump pump has a whole drilled in the side of the pvc drain about an inch under the rim of the bucket that sprays water everywhere, on the wall and even the ceiling (our floor) above. Luckily I had only a few months ago put plastic on the wall next to the pump for isolation reasons. I'm assuming it is for proper drainage or to prevent some kind of suction problem, but I find it odd that it sprays so much water everywhere. I put some plastic down over the pump as you can see in the picture. Is that the best solution?
Thanks a lot guys.
Thanks a lot guys.
