Demo'ed shower, need help with mystery pipe
taz1811
DIY virgin
Washington DC
Hi, I just demo'ed my basement shower and need some advice because I want to install the Moen 3520 valve. I'm curious which pipe is hot/cold? When I turn the faucet left it gets hot; does that mean the right pipe is hot water? Also, what is the pipe going down and turning left into my wall...and why is it only attached to one side? (I'm assuming it's attached to the cold water pipe? Could this possibly be feeding my outside hose?
Usually, the cold is on the right and that T'ed line could go anywhere. But, many shower valves can be plumbed with the water swapped and then compensate by either flipping the cartridge or removing the handle and rotating the stem 180-degrees. The simplest way to tell which pipe is hot or cold is to turn it on! You may want to hold a bucket to catch the water coming out of the shower riser. instead of it splashing everywhere. You'll be able to feel which pipe gets hot after running a minute or so. This assumes you can't easily trace the piping back to a known branch.
taz1811
DIY virgin
Washington DC
Thank you for the response.
So when I get the Moen 3520 valve, would I solder a plug into the botton opening? What is the bottom opening generally used for?
Run water from the old valve. What ever side gets warm comes direct from the water heater. Mark that pipe hot.
The four port Moen valve is hot and cold on the sides, preferably hot on the left.
The top is for a shower, the bottom for a tub. That can be capped if not used.
The mystery pipe may be feeding something like a toilet nearby.
JohnfrWhipple
BATHROOM DESIGN & BUILD
North Vancouver, BC
Do you have a pressure balancing valve in your home? We like to have the outside water line piped BEFORE this PRV or pressure reducing valve. This way you get more coverage because the sprinkle has more water pressure and goes higher!.
I bet it is like Terry mentioned and for the toilet.
What kind of toilet do you have? I would disconnect the flex line from the toilet and flush this line before using it after the new plumbing work is done. Also get your plumber to remove the cartridge and flush the old lines before testing the shower head. Simple step that could save you a trip or two to the plumbing wholesaler.
JW
taz1811
DIY virgin
Washington DC
JW
Okay, will do. Thank you. Yes. You guys are most likely correct, I have a toilet behind that wall which I completely forgot about.
