Uneven hot and cold flow after valve replacement
remodelingit
Texas
Just finished replacing valves in price pfister tub and shower valve assembly with independent hot and cold valves with tub and shower diverter valve. It looks like a pretty standard unit- I bout the valves at the orange box.
Issue: I have to open the hot water valve a couple of rotations to get full volume. I only have to open the the cold valve a third of a turn to get full volume. This makes it very difficult to establish a comfortable temperature.
Any ideas on what I can do to solve this problem?
JPB
Bueller, Bueller, anyone, anyone Bueller????
How about a response from the plumbing wonks? Beueller, Bueller, anyone, anyone, Buerller????
Sounds like the washer on the hot side stem is loose.Try pulling that stem and seeing if it is flat or beveled . You want a flat washer at least on the hot side so as it swells from heat it doesn't close off the flow.
valve
In that case, I would have repaired it differently. Your stems may have different thread pitches so they open at different rates. Does the cold continue turning after you reach full flow? Or does it just open a 1/3 turn and stop?
