Gate valve under floor?
wmichsabre
Michigan
Is it ok to put a gate valve shutoff under the floor?
I am remodeling my 2nd floor bathroom and put in gate valves so that I can plumb the shower without turning off the whole house water...since I don't have a long time each day to do the plumbing, it is easier to tackle this way.
If I never remove the gate valves, will it be ok? I probably should have put ball valves in, but that is in the past.
If there ever is a problem in the future, I could always cut a hole in the ceiling to access the valves to shut off the water.
Would like some opinions....
Mark
You could also put in an access panel.That way you would not have to cut the ceiling open.
