Sump pits
TonyBagadonutz
Electrician
NJ
I just dug a sump pit and put in a liner.
Talking with a "guy at work", he mentions that in addition to stones around the liner - I should put sand. I thought the sand would work it's way into the pit and eventually the pump. He said the sand will prevent a mineral build-up around the stones (that turns into a "concrete" effect).
So, what say and why - sand and gravel/stone or gravel/stone alone?
As always - thanks!
sump pit
if you want your sump pit to fill up with sand
go ahead and use it...
I suggest you jsut put marble sized gravel around
your pit
then either take a drill and drill a lot of holes through
the top half of this pit to let the water come through it...
I have also used a skil saw and cut slits through
the palstic before ,,,,, long cuts all throughout
the top half of the pit works great to let the water
come through b ut not the gravel
sand will simply find its way through
I put in a liner made of galv. steel - came with many pre-drilled holes to allow water penetration...similar to the item on the right:
I put in (so far) 42 cu. ft of rocks...need another 12 cu ft. The liner is about 30" deep, my hole is about 4' deep and about 2' x 4' . It's a pretty big hole dug through clay.
The idea of sand didn't sit well with me.
