Do Noble Niches Have The Bottom Shelf Slope Built Into Them?
The Noble Shower Niche is made of foam so I guess you could cut your own slope into it???
I have never used a ready made shower niche. Building a shower niche is so easy.
JW
I recently purchased several Noble Company products. I've phoned their technical support people several times to ask questions. They are very helpful and knowledgeable. I suggest you call them for any questions you have.
These things are like maybe 3" deep, and at 1/4" per foot, that's 1/16" of an inch. It would be hard to tell! Either case, it's not hard to get some slope when you set the tile on that bottom edge. I don't remember if those have a coating on them, or it's all foam. IF it's all foam, it would be easy to sand a slight slope prior to installation, or even after it was installed if you wanted to.
The niche is foam Jim. I think you could just shave a little off to be safe. I filled the one I got at a Noble Demo last year with water and left it for 7 weeks. The foam is watertight.
JW
Being foam, and wide, it's a lot easier to just sand it a little than to try to cut it in a nice, smooth plane.
