View Full Version : Help finding traditional style toilet with concealed trapway.
nowwhatnapster
12-17-2012, 10:50 AM
I am having a really hard time finding a toilet. Little background about my house. 1950 ranch with the original american "standard" ming green bathroom. Matching toilet, sink and tub. Doing a complete gut of this bathroom and saving the original fixtures for second bathroom in the basement.
My requirements are as follows:
NO ADA height, 15/15.5" bowl height MAX.
12" rough in
Single flush, either 1.6 or 1.28gal. is fine, hopefully it does not cause drainage issues. Only one way to find out!
Traditional, two piece look that does not accentuate the trapway shape. It should be flat. I do not want to see the path excrement travels. I guess I want what is called a concealed trapway, however, every toilet by that name is very very modern looking.
wjcandee
12-17-2012, 01:03 PM
The combo of NOT ADA, and must be 2-piece, and concealed trapway is a problem if you don't want it to look modern. If you'd take a 1-piece or ADA, you'd have more options.
Let me also say that most of the time toilets are installed such that you don't really see the portion with the trapway outline, but given your rather-aggressively stated concerns about seeing the trapway, I guess that's not good enough.
If you can find a previous-model Vespin CST764S or Carrolton CST774S, and it will be hard but not impossible since they have been discontinued, that may do the trick for you. I wouldn't worry about buying a discontinued Toto GMax toilet, however, as replacement parts will be easy to come by for a decade or more. You can get replacement parts for these toilets at Lowe's, made by the company that makes them for Toto (named Korky, in Wisconsin), at reasonable prices, and you can also get replacement parts directly from Toto. So that's not a concern. The trend is to "universal height", particularly in the skirted models.
I notice that Terry still shows them available in his online store, but I don't know if that means he still has some in stock; he doesn't ship, however. Nevertheless, a local plumbing supply may still have one or the other of them. You'd be hard-pressed to find them online, however.
nowwhatnapster
05-04-2013, 08:26 AM
I appreciate the post so I wanted to follow up and let everyone know my findings. After a few months of searching I located a toilet that is as close to my specifications as possible. I did compromise and get an ADA height.
Mansfield Barret 115-106
Per the spec sheet
http://www.mansfieldplumbing.com/pdf/115-106.pdf
12" rough in
800 MAP score
single 1.6gal flush
Two piece
compact elongated bowl
concealed trapway that does not look incredibly modern.
16-1/4" tall, (yes it is above my max, but it meets every other requirement, and its the shortest ADA height you can find)
Reasonably priced about $300 locally.
For the record, take off your any titanium rings you wear before handling the toilet. I managed to scratch the enamel removing it from the box. Thankfully it will be hidden by the seat.
MushCreek
05-06-2013, 01:46 PM
That's a nice looking toilet. I'll have to see if I can get one here in SC. My wife LOVES the concealed trap toilets for ease of cleaning, but we are building a Craftsman house with lots of antique touches.
