View Full Version : 3" Toilet Drain
KShirriff
11-08-2012, 05:05 PM
I have a toilet drain on the 2nd floor directly above a 2x6 wall on the 1st floor. Can I run the 3" drain from the toilet flange straight down to the basement without any elbows at the top and tie into the horizontal drain line? I have a 2" vent tied into the 3" pipe about 18" below the toilet flange and vented up throught the roof. Someone said that they think this design might suck the water out of the toilet trap. Is this true?
jadnashua
11-08-2012, 05:22 PM
That's a really long drop but it won't suck the toilet trap dry with a vent. Not sure if that would meet codes...just don't know.
11-08-2012, 05:30 PM
It doesn't matter whether it drops straight down or has a few bends.
Hopefully the bowl "does" siphon when you flush. The fill valve refills the bowl after a flush anyway. I would have no problem with a toilet drain run straight down. Wait..........I've done hundreds that way.
http://www.terrylove.com/images/dwv_b2.jpg
KShirriff
11-08-2012, 05:31 PM
should I put an elbow in it and offset it over and then down?
KShirriff
11-08-2012, 05:35 PM
Here is a pic 17802
KShirriff
11-08-2012, 05:36 PM
going to reroute the vent at a 45 degree
KShirriff
11-08-2012, 05:37 PM
Thanks Terry
11-08-2012, 05:54 PM
Running the vent for the toilet on a vertical or a 45 is a good idea.
wjcandee
11-08-2012, 06:13 PM
I was going to say that you could replace that combo with a Y for the vent, which is effectively what they are saying above.
