View Full Version : Fill Valve Spraying Tank Lid
molo
09-05-2012, 07:52 PM
The Fill Valve is spraying out of it's top. It hits the tank lid and drips out onto the floor. Is there an adjustment that can be made to prevent this?
Thanks in Advance,
Bill
wjcandee
09-05-2012, 08:01 PM
Yes. But give us more info so we can help.
Do you know the make and model of the toilet? The type of fill valve? Can you post a photo?
09-05-2012, 09:33 PM
Some fill valves will drip downward during refill. Spraying up and onto the tank lid isn't going to work well for you though. Are you sure it isn't an unused port for the tube that refills the bowl through the overflow tube?
jadnashua
09-06-2012, 11:44 AM
Look closely at the tube going to the overflow, and make sure it is fully inserted onto the nub of the fill valve, and isn't split or cracked.
molo
09-06-2012, 08:44 PM
I won't be able to provide a photo. The problem exists at my mothers house where I was visiting this past weekend (250 miles away).
I did check the flex tube from the fill valve to the overflow tube and it is not spraying. The spraying is coming from around the top of the fill valve. The fill valve looks like a modern fill valve, but it does have the floating ball w/rod.
Thanks in Advance,
Bill
