circ pump location
fsteyer
Vermont
Hallo -
I'm doing a job where the circ pumps on a hydronic system are located on the return manifold "pulling" water through the loop rather than "pushing" on the heating supply manifold. I just have never seen it done that way and am curious if that an accepted practice.
Thanks
Bob NH
New Hampshire
In a closed pressurized system the concept of "pushing" of "pulling" the water doesn't apply.
The return water is cooler and you are less likely to get cavitation in the pump if you are pumping the return water. That is significant with smaller high speed pumps that are used now. Also, the air vent is usually on the discharge end of the boiler which minimizes the air that will get to the circulator pump.
fsteyer
Vermont
thanks ... I can see your points..... why are most systems set up with the pump on the supply side?
thanks again
