View Full Version : Small bathroom choices
jthm
08-20-2012, 01:57 PM
Purchased a new home that could use some updating. One of my goals is to maximize the space of the small bathrooms.
Currently the toilets are inefficient 12" rough floor mounted models projecting 29" from the wall.
Kohler has a few shallower elongated bowl models that can shave a few inches off, but I'm thinking big.
Do I have any other options besides wall mount with an in-wall tank? I'd love the space savings, and getting it off the floor would be nice, but I'd have to relocate the drain.
Is there an floor discharge in-wall tank unit anywhere? Am I crazy?
wjcandee
08-20-2012, 03:48 PM
Um...doesn't it defeat the purpose of putting the tank in the wall if you're going to mount the bowl on a 12" rough-in anyway? It's not like you are going to design a toilet that has a trap mounted forward of the bowl...
Personal advice: if you want a toilet that flushes well, has great reliability, and has easy-to-find parts now and into the future, stay away from the Kohler. And even if the bathroom is small, unless you have a real structural barrier (like a door that swings into the toilet), stick with the elongated. I have a great round-bowl Toto Drake in a tricky spot, but in retrospect I might have just as well installed the elongated; it wouldn't have made that much of a difference appearance-wise.
Also, the overall "feel" of the size of the toilet is dependent upon more than how much it extends into the room. Our Carlyle II is actually deeper into the room than the toilet it replaced, but because of its overall size, it feels smaller and much less intrusive. So don't just focus on the one dimension. An Ultramax II or Carlyle II doesn't feel like a big toilet when it is installed, for example. The round-bowl Drake is one of the smaller toilets out there in terms of intrusion into the room, but the Carlyle II doesn't feel bigger.
I'm using Toto as an example because your default choice should be Toto. Start with them and see if they don't have what you want, because you can find them at comparable prices to the other junk out there and you're almost guaranteed to be happy with them now and over the long haul. Look around this forum (and in the user reviews section of Terry's green toilet reviews link above), to see why.
jthm
08-20-2012, 05:13 PM
I was hoping someone is making a toilet with an in-wall tank that wouldn't require moving the drain up into the wall as well. All wall or floor mounts I'm finding are horizontal discharge. That would be the one part I'd be uncomfortable doing myself.
Going from 29" to 22" would make a world of difference in that room.
wjcandee
08-21-2012, 12:35 AM
My point was that I think (although I'm ready to be corrected) that you're going to find that the in-wall-tank toilets will all be designed to discharge into the wall. I'm thinking that the logistics of getting the waste out of the bowl, through a trapway, and into a hole with a centerline 12" from the wall from a bowl that protrudes no more than 22" from the wall is going to be tough.
