View Full Version : Dishwasher drain
crosstalk
08-09-2012, 05:07 PM
Hello. I am getting ready to replace my ~20 year old dishwasher and took a look under the kitchen sink to find a separate drain for the dishwasher (dishwasher rubber discharge hose connected to copper pipe in Photo1). I also took a look in the crawlspace under the kitchen where these two pipes pass through the floor. There are p-traps on the sink drain and dishwasher drain underneath the floor before they connect into the main stack.
1. Should I continue to use this separate drain line? or use the dishwasher drain connection on the garbage disposer and cap the dishwasher drain line?
2. Is there any benefit to having a separate dishwasher drain line?
Thanks.
http://img440.imageshack.us/img440/5982/photo1ona.jpg
http://img17.imageshack.us/img17/3563/photoqjj.jpg
jadnashua
08-09-2012, 05:59 PM
Well, what you have is not up to code! In most places, the trap must be above the floor, plus, if you actually have a second trap below the floor for the sink, that's not up to code either. The top one is a S-trap, which is not valid, either. Where is the vent, if there is one?
crosstalk
08-09-2012, 06:54 PM
I don't see a vent. The main stack is a couple of feet away and each of these drain lines have separate connections to the main stack. Was this ever up to code (built in the late 60s) or just a hack plumbing job?
Gary Swart
08-09-2012, 07:03 PM
In addition to what Jim just posted, a DW drain is supposed to connect to the sink drain via the disposal if you have one or via a special wye tail piece the connects to the sink drain. In addition, the DW drain line should be connected to an air gap on top of the counter to prevent a backflow of contaminated water from the sink drain from getting into the DW. Some places allow a high loop of the DW line that loops above the DW. It looks like you have somewhat of a handyman version of a high loop. You definitely need to rework the entire sink drain to comply with code. The S trap is illegal everywhere.
