View Full Version : I can't find this plumbing fitting anywhere!
joe28_bak
08-07-2012, 10:31 AM
I hope someone can help. I have a standard drinking water filter faucet, which mounts to the sink deck with a threaded stud through which the water flows. This stud seems to have a 1/4" compression fitting thread, but you can't attach a copper tube directly with a compression fitting, as the center of the brass stud has a plastic sleeve inside that would prevent you from inserting copper tubing, and also prevent ferrule from seating correctly. These faucets come with a small adapter that screws onto the compression thread and butts up against the end of the stud, sealing with a flat rubber or plastic washer (rather than a compression seal). The other end of the fitting is a standard 3/8" compression fitting that would accept copper tubing (or a faucet supply line, for that matter.) Anyway, I need to replace that adapter fitting. Last time, I was forced to buy a whole new faucet just to get the tiny brass adapter. My thinking is that if one of these fitting comes with every darned drinking water faucet, I should be able to buy them separately. I've tried everyone from the well-equipped hardware store to Home Despot to Google searches, but I can't find the part!
jimbo
08-07-2012, 11:56 AM
The mounting stud may be 1/8" NPS ( straight) pipe thread, hence the need for that adapter which is fairly readily available at a good plumbing supply.
joe28_bak
08-07-2012, 01:56 PM
It would make sense if it was 1/8" NPS, but it isn't. 1/8" NPS threads are too small, and flare fitting threads are too big. It has to be 1/4" compression threads.
08-07-2012, 04:16 PM
I haave never seen that piece individually. I guess their thinking is that every faucet needs ONE and that is the one they send with it.
jimbo
08-07-2012, 05:21 PM
1/8" IP is 0.405" OD, slightly larger than a 1/4" male compression fitting
joe28_bak
08-08-2012, 05:09 AM
Oh well. I guess there will be two or three drinking faucets without the fitting on e-bay. In the meantime, if anyone finds a source, let me know.
