View Full Version : Toilet float doesn't sink!
veloria
12-29-2005, 09:37 AM
About a month ago, I replaced the entire insides of my toilet because it kept giving me problems. Since, then it doesn't always refill completely. I was looking at it today and I realized that the float (not a float ball, but one that is attached to the body of the valve) is not sinking. I can push it down and it will work, but it gets stuck up again the next time around. Any suggestions on how to get this float looser?
Thanks! :)
jimbo
12-29-2005, 01:15 PM
It sounds like you are talking about a Fluidmaster 400A; check to see if it is turned so it rubs on the side of the tank.
Are you talking about the fill valve or the flapper. The flapper is what goes up when you push the handle, then it goes down.
plumber1
12-29-2005, 02:14 PM
I think hes talking about the ballcock.
Mike Swearingen
12-29-2005, 09:46 PM
If it's a float-cup type refill assembly like a Fluidmaster 400A, you need to hold the float cup under water at first to get it to work properly.
Mike
Mike
That has not had to be done since the original 400's which had the open cup.
