Iron and low Ph problem
Kendallroad
I woul like to replace my calcite neutralization system with a solution based injection system.
I would like to use a water controled dosing pump using a soda ash and hydrogen peroxide solution to cure my soluble iron and low Ph problems.
Any information as to the as to the type pump to use.
My well pump has a output in the 10-15 gpm range
Thanks,
Peter
how about using an lmi, stenner, or seko injection pump with water meter you could use the water meter to hook up to one pump and have the other inject of the first pump. I would use soda ash and chlorine then you'll need a contact tank and a birm or nextsand filter.
