View Full Version : All things Washer related - for drain tubing
chefwong
07-02-2012, 05:03 AM
Its been awhile since I've had to change/install plumbing under a sink.
Noticed new *rubber* washers for slipnuts, rubber tailpiece washers as well.
Are there better/superior when using brass tubular.
I've always used the nylon variant.
Not sure how much this is used, but on my trap arms-trap...there is also a O-Ring where the trap arm mates with the trap. Anyone else using O-Ring in any of these places.......O-Ring lasting longer than some of the rubber washers on the market ?
07-02-2012, 07:11 AM
They are NOT "new" rubber washers. Rubber washers were used for DECADES before the plastic ones were invented. Sometimes they are better and other times not. If you apply pipe dope to the washer before tightening it, it will rot the rubber washers.
chefwong
07-02-2012, 07:41 AM
The tapered rubber slipnut washers are new to me.
On brass tubular, is the rubber a better fit versus the nylon ?
Aside from Gas Tite, the only dope I have is my stash is Real Tuff Teflon...which is safe for Rubber afaik
07-03-2012, 06:42 AM
All the rubber slip washers I have seen are "square cut", not tapered, but with rubber tapering would not give any benefits, and might be a detriment since the rest of the washer would have to deform to force the rubber to fill the slip nut's "gap".
