View Full Version : Old out faucet leak
ellaryk
06-23-2012, 02:16 PM
My house was built in 1968. The outdoor faucet is not frost free. It comes straight out of the wall with the handle at the end and the spigot down at a 45 degree angle with a hex nut shape as part of the casting about two inches from the handle end. See attached photo.
It leaks from the handle when the faucet is on. there is no leak, as you can see from the photo, when the faucet is off.
What do I need to do?
16637
Smooky
06-23-2012, 04:01 PM
I think that is a frost free faucet. You may be able to tighten the packing nut and stop the leak. More than likely the packing washer is bad and needs to be replaced. To remove it, first turn off your water. Then you can remove the handle. You may need to put the handle back on after you remove the packing nut so you can pull everything out. The big hex nut is the packing nut and should unscrew but it may be reverse thread. Here is a link to a similar style wall hydrant. I have no idea what brand you have but it looks like Prier. It sorta looks like I can see Prier in the paint.
http://www.griggindustries.com/page313.html
ellaryk
06-23-2012, 04:19 PM
It is a Prier. I increased the size of the image and PRIE is easily read. Is there a way to tell if it's reverse threaded?
Smooky
06-23-2012, 05:27 PM
I found this in the link below. You should be able to find what ever you need in these links. Looks like good info:
Question 1: When the water is running there is water leaking from behind the handle.
Answer 1. This is a common maintenance occurrence for any packed valve of any brand or manufacture. It is overcome by simply tightening the packing nut with a crescent wrench. This will force the packing tighter around the stem to eliminate leakage.
Occasionally, the packing will need to be replaced if the packing nut has been repeatedly tightened.
The parts required for this is a C-134KT-803 Packing Kit
http://www.prier.com/products/residential-hydrants/c-134-prier-original-design.html
http://www.accentshopping.com/product.asp?P_ID=153720
MACPLUMB 777
06-24-2012, 05:47 PM
#1 remove handle
#2 remove big packing nut making sure to keep faucet handle off
#3 take a appox. 6" piece of teflon tape twirl between you fingers till it becomes a 6" thread
#4 wrap around faucet stem clockwise
#5 reinstall packing nut being sure not to over tighten test this by opening faucet a little bit and slowly tighten packing nut till water stop leaking out
#6 reinstall handle
their you are good for another 25 years or so
ellaryk
06-25-2012, 04:01 PM
Thanks. But removing the handle is the hard part. The screw won't budge. I've been spraying it with PB. Do you have any tricks for loosening it? Or can the Teflon tape be installed without removing the handle?
#1 remove handle
#6 reinstall handle
MACPLUMB 777
06-26-2012, 11:53 AM
No you must remove handle to packing nut out far enough put teflon string in
