View Full Version : Using Oatey EPOXY PUTTY Still Leaking
JoeD
12-26-2005, 10:16 PM
Using Oatey EPOXY PUTTY to stop a very small drip in my baseboard
heating:
1. Started by really cleaning copper pipe
2. Used about 3/4 of the Epoxy Tube
3. After a day I still have a drip much much smaller
4. Found the drip used about 1/4 of the Epoxy Tube
5. After a day I still have a drip much much much smaller
6. Found the Drip used about 1/4 of the Epoxy Tube
7. After a day I still have Some water not a drip
8. By now I have a large amount of Epoxy
and the DRIP is Slowing down?????
I Need HELP with How to apply the Exopy.
Should I Keep using the EXOPY on this small leak.
The leak is so small I feel I should beable to WIN.
I don't want to put in new copper until the Spring
it's the lower loop and it's relay Cool and I just wanted the Epoxy to hold
for a few months till I can fix it right.
Thanks
JoeD
12-27-2005, 06:15 AM
Are you removing the pressure from the pipe before you apply the epoxy and while it hardens? If not it will always force a way through before the epoxy seals.
jimbo
12-27-2005, 08:31 AM
Rectorseal makes an epoxy embedded fibregalas repair wrap.
rshackleford
12-27-2005, 09:40 AM
Google "hydrowrap." They make a material similar to casting (like if you break your arm) that can be used under all kinds of pressures and on all materials.
However, i would guess that you don't have the room to get a product like this installed.
dubldare
12-27-2005, 08:53 PM
:eek:
Wow.
Sometimes you just have to bite the bullet and fix it correctly, even in the winter.
Cass
12-28-2005, 05:27 AM
Yup.... sometimes you do.
JoeD
01-08-2006, 09:12 AM
:eek:
Wow.
You are RIGHT - It's all fixed - Thanks
