Air in pipes??
laldybug
Everytime we flush the toilet it sounds like a train going thru the house. Can someone walk us thru the solution? It only started about a month ago (we are at our 2nd home, that's why we let it go so long, but now we are here for a week). Once the toilet is flushed it takes about 15 seconds before we hear the noise slowly get louder and louder (sounds like air in the pipes). If we turn on the water in the sink it helps somewhat. The sounds lasts for about 10 seconds and goes away. Can this be done by us or do we need a handy man or plumber? Waiting for you reply. Many thanks and happy holidays.
Are you on a well? If not a well you can try and replace the fill valve and supply tube. Get a Fluidmaster 400A and a flexable braded stainless steel supply tube. They can be had at any big box store.
Only you will know if you can do it. We can walk you through it if you decide you want to try it, it's not to hard.
My guess is that it only sounds like air as if it was air you would be getting it at other faucets.
Cass is right, more than likely it's the fill valve.
Before you work on that, make sure the shutoff to the toilet is fully open.
Sometimes these are turned down and the rubber will vibrate.
A quieter valve than the Fluidmaster is the Quietfill by Korky.
Air in pipes
Thanks everyone for your reply.
We are on a well - do you still recommend changing the valve? If so where is the valve that you are referring to? Would it be in the tank or in the basement? As you can see I know nothing about this subject.
Have a great day and happy new Year to all!
