View Full Version : Connecting chrome brass to plastic pipe
Jwhitman
06-04-2012, 03:10 AM
This may seem like a dumb question, but I have to ask. After a recent bathrooom sink installation the drain was offset considerably and the hook a little odd. I started out with brass pipe wall drain and p-trap then a flex up into the sink. The flex leaks where it connects to the p-trap. I just used the standard slip joint gasket that came with the p-trap. Should I use a different seal.
Thanks,
J
jimbo
06-04-2012, 06:18 AM
Flex pipes under a drain often lead to problems, but....as long as you have the fitting plumb where it connects to the trap, a regular slip joint gasket is all that is required.
06-04-2012, 07:00 AM
With the correct drain fittings, there is NEVER a justification for using a flexible drain pipe. They are "illegal" and cause problems.
jimbo
06-04-2012, 04:44 PM
. "illegal" .
As in "sick bird"?
http://www.clker.com/cliparts/e/1/5/a/1197085805318766290johnny_automatic_a_sick_bird.sv g.med.png
