EMAGINEER
12-23-2005, 06:04 AM
There is a toilet in my laundry room....located between the washer/dryer. Actually, it is installed where the dryer should be sitting. I want to remove it permanently. The main bathroom toilet sits directly on the other side of laundry room wall.
How do you seal the opening/drain when the toilet is removed? Is there a possibility that the two toilets are using the same drain and will sealing one opening pose a problem with the bathroom toilet?
Thanks
Thanks
