Ze'ev Garber
I'm remodeling my basement bathroom. There was toilet only installed in laundry room in enclosed cabin. I have cleaned the room and removed appliances, toilet, cabin.
I'm splitting the room into 2 rooms - one for full bath and one for laundry with the wall separating both and 2 separate doors.
I'll be using caroma rear outlet toilet and plug all drains (bath tub, sink, washer and toilet into one 4" pvc that will connect horizontally with old cast iron stuck.
The problem is that I only have 3-4 feet between the back of the bathroom wall and existing stuck that I want to connect to. So pipe does 90 degrees and then has four 2 inches pvc pipes connected to it.
Would it be an issue to contruct the pipe as on the picture? I'm just designing at the moment and have not connected anything yet.
Thanks for your advise.
Jeff.
Jeff.
