Trying to make mini Pump up for Bar Sink
gdodd12
ATL
I am looking to install a sink in a bar I am building in my basement. Unfortunately it is on the other side of the basement from my existing Sewer ejector that is used for my basement bathroom. I was wondering if there was a mini self-contained ejector system I could use that sits above ground, just to push the sink drainage over to the main system area. The place it would be sitting is all unfinished, so access isn't a problem. I just need to figure out a way to pump it up and over to main sewer line. I also thought about using a regular condensate pump, but with the largest one I have found having only a gallon tank, I feel it would fill quickly. I also don't want to pay to have a hole dug for a whole new pump up system just for the sink.
Thanks
I have had no luck googling. Can you point me in the right direction? I assume I would then be able to use this pump to hook up to my outgoing sewer line the same way as my bathroom ejector system is doing it?
