Hi, plumbing gurus.
My city house is fed by 1/2" galvanized steel, and the static pressure is 30psi but the flow is low, so a toilet flush reduces a shower to a trickle. I've replaced all house pipes by 3/4" copper from the water meter myself.
I've received quotes of >$10K to replace the city line (eeek!). Question: could my problem be solved by adding a captive air tank after my meter? My meter is in the basement of my two-story house.
Other considerations: Would I need an auxiliary pump? Do I need a backflow valve? What size tank - is 85gal enough?
Thanks in advance for advice - this solution could save me a lot of money since I can probably put this in myself for <$500.
