The toilet must vented before the introduction of the laundry.
The laundry is causing venting problems there. It's all bets off for wet venting unless you can use the lav to wet vent the toilet. The laundry would need to be downstream of the bathroom, and the toilet.
The fix it to vent everything before it hits the main line. You want to fix this before you cover it. Once you are done, you will wish that a few more fittings were used.
