overflow cover was pulled away from the tub wall but screw still very tight
Belle
Alberta
Hi my name is Isabel, It's my first time to this forum, I have problem with my almost 2 years installed acrylic bathtub. The installer covered the old bath tub from their custom made product. My problem now is the one screw overflow cover was pulled from the bathtub wall but the overflow cover screw is still attached and very tight can't tight anymore, the easy fix I did is to use clear bond to glue it to the tub wall.
Is there any professional suggestion you can give me?
I will appreciate it very much.
Thanks,
Isabel
IF the screw is the "only" problem, get a shorter screw or cut that one off. But, since what you describe should not happen, or even be possible, unless the rubber gasket behind the tub has disintegrated, you may have a bigger problem than you think.
