Quarter-turn, frost-free, anti-syphon faucet shuts itself off
RavenG
Long-time DIY
Dolores, CO
Hello,
I have two quarter-turn, frost-free, anti-siphon faucets, both installed in 2005, that shut themselves off when water is run through a hose. I hear a gurgling sound and then a "clunk" and the water volume shuts down to a trickle. It occasionally leaks around the top cap, but not always.
These faucets were, stupidly, purchased at Home Depot and installed in our new home. Based on reading threads on this site, I think they may be Mansfield 500-series faucets - or possibly NIBCO Model 90??. There is no manufacturer name on them (obviously not proud of the product) only A.S.S.E 1019-A on the anti-siphon cap and embossed in the brass on the left side. There is also SA enclosed in a large C on the cap. The handle and cap are made of tan-colored plastic. There used to be something written on the end of the handle, but it faded away long ago.
Does anyone know what is causing this reduced volume problem? I've taken both faucets apart and there is no internal blockage and they both run fine if there is nothing attached, like a hose. The problem is worse if the hose is going up hill from the faucet. The cause seems to be in the anti-siphon/vacuum-breaker mechanism, but I can't figure out why.
Based on what I've read in other threads, it looks like I may need a Mansfield service part kit vacuum breaker pack No. 630-7500 (or possibly vacuum breaker replacement parts for the NIBCO Model 90).
I would replace these faucets with a better brand (one that is proud enough to put their name on it and for which replacement parts are easily available) but I would have to tear out two finished walls to get to the inside end of the installations & destroy the stucco finish around the outside. I don't want to do that if I can avoid it.
I only saw one other post who mentioned the reduced-flow problem with these faucets, but I could not find an answer to his question.
Thanks. Any help would be much appreciated.
Hello,
I would like to know the answer to this question above please I have the same faucet and the same problem
Replacing all the internal components & the atmospheric vacuum breaker should take care of it since replacing the entire unit isn’t possible. Most of the ceramic disc style quarter turn frost proof sillcocks are made by the same factory. Most on-line distributors like SupplyHouse.com carry parts and/or new units.
