Culligan Gold/Silver Regenerating daily
Dankon
Dallas, TX
I have a Culligan Gorld or Silver softner. It regenerates every day. The #8 screen says "08". If I'm reading the manual right, this means it should regenerate every 8 days. I guess I could have the "soft-minder" - how can you tell if it is the soft-minder or time-clock model?
Culligan used a few different controls on the gold or silver systems, so not sure about the number 8.
Are you hearing it clean every night?
Photo would help.
The metered system has a part that is between the valve body and the bypass and there is a cable from there to the control head.
Yes, it cleans every night. I'll upload some photos tonight. Screen #8 is supposed to be the "regeneration interval", which should be Gallons (divided by 10) if unit has a soft-minder. If not, it should represent # days to regenerate.
Sent a PM
It is possible that if meter count is off, say 135 turns for each gallon for the correct count and if that number changes then the gallon count will change.
A big sign for the difference between the metered unit and non metered is that the non metered or day will have the bypass up close and personal with the valve body, metered will have some space between the two for the turbin.
The default day could have moved to 1.
Is the display changing ? or is it stalled in one spot?
I don't think I have metered. Screen #8 (regeneration interval) says "8". Display is not changing.
It is possible that the control board is locked up, as you should be able to step it through the different stages of the programing.
I am able to step thru the different stages of programming ok. On step# 8 of programming is the "regen interval". It now displays "08" for that. Here's a link to the owners manual: http://www.eculligan.com/support/gold2002.PDF The programming step I'm refering to is page 10, step # 8.
Pretty sure it's an older Gold Series model without the flow meter. I have included a couple of photo's (sorry for the poor quality). IMG_0691.jpgIMG_0693.jpgIMG_0695.jpg
If it is the metered then there is a cable going back to the out side of the valve body right at the bypass valve on the blue side of the handle.
Send a pm, there is a manual that has more on that board, might need to be reset.
Right click on my nick and a list will show up, then click on the send message.
Sorry that I did not get back to you sooner.
