DRIFT-O-MATIC
- Messages
- 2
- Reaction score
- 0
- Points
- 0
I just purchased a 12 year old house in Clearwater, Florida. I plan on converting the formal dining room into a third bedroom, since it will never be used as a dining room. It’s too far away from the kitchen. Anyway, the only place I can install a closet door in the new “bedroom†falls right where there are copper manifolds coming up from the concrete slab. These are half-inch hot and cold lines feeding two bathrooms and a detached garage. They stand up about 7 inches above the surface of the slab, and take up a floor space of about 1†X 10â€, and are located inside a 2 X 4 frame wall. My question is, can I carefully chip away by hand the slab around the copper pipes, re-locate the manifolds below the top surface of the slab, and then re-cover the manifolds with a piece of plywood, so that it is flush with the slab? This area would then be the floor of the closet, and be covered with carpet or something. Would there be any problems with doing this?
