Vespin ii doesn't fit - supply line blocking access.
Spacepod
Socal
Hi there,
Love the site, very helpful.
I have a new Vespin II with 14" rough replacing a Briggs unit. The water supply is about 4.5 inches off center, if that. It has a full knob on it, nothing fancy from the wall. Should I use a 12" rough and 90 elbow joint with a quarter-turn Dahl valve or get a qualified plumber to move the supply over to the left so I can use the proper 14" rough? Legroom is not an issue but I don't want the toilet too close to the tub, and I know the 14" rough is correct and I already bought the 14" Unifit adaptor.
Floor is just linoleum, nothing fancy.
Ideas?
Thank you
Pod
Gary Swart
Yakima, WA
If you will look at the previous thread, "Toilet water supply turn off too close to the floor", you will see where Terry added some valve options to my response to the question.
Spacepod
Socal
Thanks
Hi there,
I ended up having a plumber come out and move the supply line over more. This way I can use my 14" Unifit as-intended. The cost was the same as if I just had him install the 90-degree elbow and adaptor...service call + any parts so I went with the better option.
Great forum here and thanks for the reply.
Spacepod
