Hackney plumbing
Homeowner
If they leak do you replace them period? If they only leak alittle bit then I leave them. Like 150 cubic centimeters per hour I just leave it.
Not in the trades, but if I were I would replace it free of charge before I thought about walking away...and no, I wouldn't be the lowest bidder on every job.If they leak do you replace them period? If they only leak alittle bit then I leave them. Like 150 cubic centimeters per hour I just leave it.
How would you live with yourself if the next day the house blew up and killed the entire family? Suppose you took you truck to a repair shop to have a radiator hose replaced and the mechanic found just a small gas leak dripping fuel on the manifold. Would you expect him to leave it? Are you so darn afraid to do something that you might not get paid for that you would allow a potential fatal condition exist?
Yep but so what? there's all sorts of sub standard standards out there. We should be above the minimum whenever possible don't you think?
I do leak test every single time I,we service any gas equipment or piping and yes, we use an electronic sniffer and yes, if it leaks we change it and no, they don't leak very often so until you brought the issue up, it wasn't an issue. Still isn't, but it's your company and you can run things any way you want to. I ain't telling you what you do is right or wrong only that it ain't what I do. Hey while I have you, who made the stock you put on your Ruger 10/22 was that a Tapco or ATI? and do you like it so far?
