Central Air - Hot water
Coopns
Massachusetts
I see adds for Central Air via hot water pipes. I have baseboard forced hot water heat. Any advice/recommendations/expense?
(Wasn't sure which forum)
I'm not up on everything by any means...but, if you were to add a chiller and tried to run cold water through your baseboard system, you'd have a real mess on your hands! The condensation would create a huge mess and it wouldn't work very well.
It is possible to run chilled water through a hydro/air heat exchanger, but it needs a fan to move the air into ducts and some means of condensate dispursal/drainage.
There are high velocity, small round duct systems that can be retrofitted, and many choices on minisplit a/c units that may be easier to install in a home that has no existing ductwork.
Basically, you need to move the hot/moist air over a cooler surface, draw some moisture out when it chills the air, then get that air to the room(s) where you need it. Not going to happen with a simple radiator without fan(s). then, you have to deal with the condensate.
Point me to one of those ads- I have no idea what they're hawking (and just when I thought I'd seen EVERYTHING!!)
When they used chilled water for air conditioning, the "radiators" were installed at the ceiling because cold air falls down, and they also had to have a trough to collect the condensate and direct it to a drain point.
