Drake Differences & 11" rough-in Qs
TG284
Illinois
After a lot of reading here, it looks like the Drake is probably my best option for compact size & my 11" rough-in requirement.
Are all drake cst743 round models created equally (newer, older, Eco 1.2, 1.6)? So if I buy from somewhere with older stock or the latest batch, does the 11 to 10 7/8" rear clearance likely still apply? Ive found a few spec sheets with different rear #s, just want to confirm.
Might any of the Aquia models or newer contemporary looking/smaller tank units work with the 11"?
Thanks Guys
More on Drake and 11" rough-in
I've seen on this forum that the Toto Drake can make do with a 10-7/8 rough in.
So does that mean that if I measure 11" from the wall to the bolts of my current toilet, then I'll have only 1/8 of an inch to spare?
If so, I better make sure my measurements are accurate!
At 11" you only have an 1/8" to spare.
The horn is 2-5/8" going into a 3" drain. There is some room to fudge a bit at that point. But......you won't know for sure what you have until the bowl is pulled.
The Aquia fits at 11.5", but also can be ordered with a 10" bowl CT412MF.10 that works at 9.5"
The Drake CST744EF.10 works at 9.25" too.
Thanks Terry & All, after finalizing tile im now working with ~10.5"... So 10" rough in it will be
Am I correct in finding that the Drake 10" is NOT offered in round, only elongated? Any other shallower depth 10" toilets that i've overlooked?
I am a click away from ordering the Aquia 10" (CST412MF.10), I like the narrow tank and even though it is elongated, a 27.5" depth. Any other significantly shallower toilets, or ones that tuck the wall best for 10.5"RI that come to mind, lmk.
Thanks again!
