Low water pressure
GurneyHalleck
Hayes Virginia
Just installed a new big box store 3/4 HP shallow well jet pump to replace my old 1/2 HP gould, which died. The unit has a 20/40 switch, so i had 18 psi in the pressure tank when i primed the pump but it never got above 20psi and so never shut off. Not being a plumber, i thought maybe i had it wrong and should have had 2 pounds less than the cutoff value, so i cranked the pressure tank up to 38 psi and the pressure went up to 40 and shut off. After using some water, the pump reached its 20psi cuton value and started cycling again but this time never got above 27psi. The well water is notoriously dirty at times (it clogs up the pressure switch every 2-3 months) so i'm wondering if it could have lowered my water pressure that quickly. I had rigged the system to first pass through a sediment filter but with that arrangement, water pressure never got above 10psi, and no water was delivered to the house (10ft. above pump level) so i disconnected the filter. Any suggestions?
